- 29 Aug 2007
Got the system below, dont really intend to overclock too much if at all initally but would like the system to run as cool as possible, dont really want to spend £30 ish on a cpu cooler but between 10-20 pounds would be fine as long as I would see a drop in temps from what the stock AMD would do. Any opinions appreciated, or should i save the time and go for a more expensive one. Also needs to be easy to fit to my Mobo.Thanks in advance
M2NSLI DELUXE AM2 NVNF570 SLI ATX SND+2XGLN+1394+U2 SATA Motherboard
AMD Athlon 64 X2 5600+ (2.8GHz) Socket AM2 2MB L2 Cache (2x1MB)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
