Cooler advice
3 May 2011
Leicester
Morning all, I'm finalising some bits on a build I'm currently doing but I'm torn between 2 models of CPU cooler and could do with some advice.
I have an i7 4790K processor and the case is an NZXT H440. I've been looking at the NZXT Kraken X61 but wondered aside from size if there are huge benefits on this over the X41.
Which of the 2 would everyone recommend?
I've got an X41 on it's way to me, but if I had the space I'd go as big as I could.
More surface area = more fans = lower fan speeds which ultimately means it will be quieter, one of my requirements is as low noise as possible, if it isn't one of yours then you might get away with the smaller cooler and higher fan speeds.
