As you can see in the included images, my cooler is seated preeeetty damn tight to the RAM. The fan that comes with it has some rubber feet attached for where it fits on to the cooler. Problem? Problem is the feet only attach to one side. The way I see it, my options are...
1. Remove 8GB RAM (no thanks!)
2. Put the fan above the RAM, meaning the fan isn't perfectly aligned to all of the fins on the cooler and also if I ever want to change the RAM I have to remove the fan.
3. Put the fan on the other side, but it won't have any rubber feet between fan and fins.
4. Get a new cooler - preferrably not after all the trouble I've gone through with this one, the last thing I want to do is clean up the CPU again.
5. Hidden option (you tell me
So... which option do you go for?
