Cooler for 5820k
3 Nov 2014
Newcastle, England
I currently have a Corsair H100 and I am upgrading to a 5820k and a new case, but on my current setup, the H100 dosent do a great job of cooling anymore which leads me to believe something in it is broken...
I am looking for a new cooler, or a way to test to see if my H100 is working.
Air or Water, aslong as it looks Good and is compatible with Avexir Core series DDR4.
Cheers lads!
At stock settings (having removed the guaranteed "step 1 overclock" for now, which worked, just don't see the need for it currently), the Asetek AIO that came with my 8-Pack bundle is currently 20C using the pre-applied thermal compound.
Edit: It barely exceeds ~40C while gaming.
I almost bought a used 5820k the other day with a Corsair H110i GT so I don't know if it's the best cooler but it's the one I would have gotten & apparently good at cooling the CPU when overclocked..
Any large air cooler rated for a 140W CPU or 240mm+ AIO will do the job fine.
Can you see the RPM from the H100 by plugging it in to a fan header? Does it slosh excessively when you shake the rad as maybe it's just lost coolant over time.
Which thermal paste should I get to go with it? Not looking to pay a tenner, would also like enough to do my 290 aswell when I get the Kraken G10 and H50.
What are yous using for case fans and on the rad?? I am looking at the OCUK ones that come with the rad, to make them all match up!
