Cooler for 9800x3d
The thing is my room gets very dusty so I’m not sure but I wasn’t aware of if an aio fails then the cpu will get fried, is that a likely thing to happen
If your CPU hits a dangerous temperature your PC will automatically shut down.
I don't know why your room is particularly dusty, however that will result in similar issues with both AIO and traditional air cooling. An AIO is not passive, it still requires fans, warm water isn't cooling a hot CPU. You're going to need to clean the PC frequently regardless given what you said.
The Arctic Freezer 3 is a fantastic AIO if you go that route, however be aware that it uses slightly thicker radiators than traditional AIO's. In terms of cooling that's a positive, but it also means it might not actually fit into your case, so you'll need to research that.
Personally I'd go for air cooling unless you're wanting the aesthetics of an AIO, the 9800X3D, especially if you only really game, is not going to require more than that.
pump failure isn't common, but there is a slim chance. I don't know what the failure rate
Unless you notice it high CPU temps you could be using it with it no longer working. Unless you run coretemp often etc. I've emailed artic to include a buzzer in case of pump failure, that extra feature would be useful.
Your PC dust filters will reduce the amount of dust, so it's probably the same- just that the AIO fins are tighter packed so dust more likely to clog it up. A clean every six months should be fine.
Air cooling is good if you just fit it, leave it and never have to worry about, zero maintence. But WC does offer better temps quick search for that CPU . probably more required for the very hottest Intel i9 etc.
My 9800x3d with PBO overclock hits about 83-84 degrees after ~12 minutes of Cinebench Multi Core. I use a Thermalright Peerless Assassin 120 dual tower/dual fan cooler. I previously had a Deepcool single tower/dual fan cooler and with that one the 9800x3d hit 93 degrees under max load, which was too close to the thermal limit for my liking. So I upgraded.
During gaming sessions I max out at around 61 degrees (72 degrees with the previous Deepcool cooler), but the CPU load is usually well under 40% in the games I play. Idle temps are mid 40s.
All the above is with a room temperature of about 22 degrees."
In the case of pump failure and it were to go all over your PC, how would that fair with warranty etc and all your other parts? Will the whole PC be knackered and have to buy a new one or do artic replace everything for you?
And for air cooled would you put 3 fans at the top since you won’t have a massive radiator at the top for extra fans?
Yeah I’m not sure why my room gets dusty either but it’s very annoying. My siblings rooms all seem to be fine but for some reason the skirting boards and floor desk just get ridiculously dusty.
a few in here have let me know with my particular case that the aio artic would fit but iam leaning towards just air cooling giving me a lot more piece of my mind and yeah I’m only going to be gaming on it and just a bit of work with VMs so nothing major.
As for aesthetics I really don’t care what my PC looks like as long as it runs fine
