Cooler for an Intel i5-12600k?
26 Oct 2002
Middlesbrough
Can someone advise me on a cooler that I can use on a potential new build?
The Cpu will be an Intel i5-12600k. All the ones I've been looking at mention an adapter.
Budget will be around £70 to £80 all in. Ideally a water cooled solution but if there's a better air cooled option I'm all ears.
Hoping to order something tonight so I'm in a slight rush.
Kind regards.
Edit - realise I've put the wrong cpu in the subject heading. What a tool.
Corsair H150 cappelix works, you'll need to order the screws from corsair though, cost is about 3 quid.
https://www.overclockers.co.uk/cors...id-cpu-cooler-360mm-cw-9060048-hs-042-cs.html
Retro fit kit.
https://www.corsair.com/uk/en/Categ...nts/Cooling/LGA1700-Retrofit-Kit/p/CW-8960091
Alternatively,
https://www.overclockers.co.uk/ek-w...-in-one-cpu-water-cooler-360mm-hs-00k-ek.html
And the mounting kit
https://www.overclockers.co.uk/ek-water-blocks-ek-aio-lga1700-upgrade-kit-hs-00l-ek.html
There's more to choose from in the range, I went down the Corsair route.
Air cooler for silence: Noctua NH-U14S
- No pump noise
- No fan noise
- Same temp as AIO
- No leak or other failure
- 6 years warranty
- lifetime free socket upgrade kit (as with ALL Noctua heatsinks)
