Hello. I've been doing some research on a new rig for about 3 months now. I'm going to be using it for gaming and music production. I've been researching for 3 months as I want to make sure I'm spending my £1000 to the best that I can.
The spec below is finally what I've decided to buy!
But seeing as I'm going to be using this computer for long periods of time, I was just wondering if I'll need a cooler? Just as a side note, I won't be doing any overclocking, not sure if this helps you...
Here is my spec:
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£59.95 £59.95
HD-087-WD Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM (HD-087-WD)
£98.95 £98.95
MO-019-OK OcUK Value Hanns-G HC194D 19" LCD Monitor - Silver/Black (MO-019-OK)
£104.99 £104.99
KB-054-MS Microsoft Comfort Curve 2000 Keyboard (KB-054-MS)
£11.99 £11.99
KB-026-MS Microsoft Basic Optical Mouse - Retail (KB-026-MS)
£9.99 £9.99
MB-011-IN Intel DP965LT 965 (Socket 775) PCI-Express DDR2 Motherboard - Retail (MB-011-IN)
£69.99 £69.99
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£116.99 £116.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£119.99 £119.99
CD-035-NE NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-035-NE)
£19.95 £19.95
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£66.99 £66.99
OS-001-MS Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01528) (OS-001-MS)
£52.99 £52.99
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£125.99 £125.99
Subtotal £837.80
VAT £146.62
Total £984.42
This is what it lists for the Antec Sonata II case I'm going to buy:
Would this case be OK or would you recommend getting some kind of cooler?
Thank you so much for your help!
Many kind regards,
-Alex.
But seeing as I'm going to be using this computer for long periods of time, I was just wondering if I'll need a cooler? Just as a side note, I won't be doing any overclocking, not sure if this helps you...Here is my spec:
£59.95 £59.95
£98.95 £98.95
£104.99 £104.99
£11.99 £11.99
£9.99 £9.99
£69.99 £69.99
£116.99 £116.99
£119.99 £119.99
£19.95 £19.95
£66.99 £66.99
£52.99 £52.99
£125.99 £125.99
Subtotal £837.80
VAT £146.62
Total £984.42
- 1 x rear 120mm Tricool fan (standard) with 3-speed control to balance quiet with cooling
- 1 x front 120mm case fan (optional) 25mm thick
- 1 x 92mm fan (optional) in the air duct to cool the CPU
- 1 x 80mm fan (optional) for graphics cards
Many kind regards,
-Alex.
