Cooler less than 150mm for the Ryzen 7 5800x
27 Jul 2006
Huddersfield
Ive been looking round for a cooler for the above and am having problems finding an AIO that fits in the case so am thinking i may need to go for air.
Id like it to be rgb but its not essential.
Its for an itx board and my ram is 48.7mm hight.
Board is the X570 I AORUS Pro Wifi
Case is the Corsair Crystal 280X
Any help would be great.
I'd look at something like the Noctua NH-U9S if you want air. (Chromax version if you prefer black)
That said, The 280X, should easily take an AIO. Corsair even list those which are compatible.
It says it can fit the following rad sizes: 120mm, 140mm, 240mm, 280mm
