- 12 Feb 2014
Quick question about CPU temps. I have just upgraded to a cooler master 212 evo cooler from a stock Intel one. Before switching, my i7 3770s had good temps and stayed fairly static when idle.
With the new cooler fitted and all the same hardware the idle temps flicker from 19 to 29 a few times a second on two cores and 21 to 26 on the other two. If I load it with prime95 they only go up and down by a few degrees.
Is that normal behaviour? I cleaned off the old thermal paste before applying new paste that was supplied with the cooler.
