Cooler Master 612S, does yours move ?
12 Jul 2012
Ive noticed this before as the bolts on the back don't seem to tighten very much due to having springs on the other side, their is very little tension against the CPU.
I had to remove one of my fans off the CPU cooler today to get at the 4 pin power cable to fit a braided extension, i could feel the CPU cooler moving, that can't be good for the bond with the thermal paste.
Is yours the same where you can't tighten it a lot with the nuts on the back which causes play on the cooler itself ?
