- 2 Jan 2014
I am upgrading my case to the corsair 250d and wanted to water cool my CPU. I came across the Cooler Master Eisberg 240L and as you can expand this water cooler, would it be okay for the coolant to go from the CPU straight to the GPU without a radiator inbetween? or if i should add a dual 80mm rad between the CPU and GPU. Also how hard is it to expand the loop?
