Cooler Master Elite 335 side window
8 Nov 2002
Parson Drove near Wisbech
Hi, I am cutting a side window in my case panel so that I can fit better cooling, I am using 4mm perspex and I was unsure how to fix it to the panel, any advice you can give me as I would like it to look really tidy and I really do not want to use just a normal nut and bolt, Thanks for any help you can give me.
Regards, Wayne..
Edit: Another thing when the window has been cut what is the rubber stuff called that goes on the panel to stop sharp edges and also so it finnishes off looking better..
