cooler master elite 335
18 Aug 2010
Scotland
I'm adding a 1tb hd in a couple of weeks, but do any happen to know if i need to buy tracks or something for the hd or?
ty in advance
think that case has a tool-less system so you wont need anything, the most you would need is 4 screws which would have come with the case and or hdd
Looking at the case specs, there are 6 3.5" drive bays, meaning up to 6 HDDs. So assuming you don't have that many drives, then no you won't need any tracks. Looking at the pictures of inside they seem to be screwless slots too, so all you need to do is slot in the drive, lock it in and you're ready to go. Just make sure you have a spare SATA sable to connect the drive to the motherboard as most OEM drives just come with the drive itself :).
