Hello
I received and set up a Cooler Master H500M.
I have some questions about it
I would like to put a led strip inside but the tape I have does not work on the RGB controller. Likewise, I can not connect it to the RGB jacks of the case because when plugged in, an unpleasant sound is heard. Would you have led strip RGB to advise me? (not ARGB since the fans are on the ARGB socket and I would like a strip of led with a fixed color)
I've ordered those, would it do the job?
https://www.amazon.fr/gp/product/B0...-W8F1u6xp7tbFDROiwecPXN2Doa3KgxZh3oHXCOKvAwbI
I had to mount the fans above the radiator otherwise it did not pass, they are exhausted but outside the tower. Will this affect the performance? (view the pic)
Since the fan are not blowing through the rad, would that be an issue?
thank you
thank you
