Cooler Master HAF 912 Case - Only £52.99 inc VAT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
For those of you on a tight budget I have secured stock of the HAF 912 (none Plus edition) it's the same as the HAF 912 Plus but the interior is not black, its silver in colour. It does save you almost £20 against the Plus Edition though :)
Cooler Master HAF 912 Case - Black @ £52.99 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912. To carry the mission of providing the best thermal solutions, HAF 912 supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates six 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.HAF 912 features rugged looks, massive air cooling and trademark interior that signifies performance and makes it a killer machine.
- HAF 912 is built in aggressive design.
- The compact interior able to accommodates 12 devices.
- Supports long graphics cards including Radeon HD 5970 and NVIDIA Geforce GTX 480.
- Superior cooling performance support up to six 120 mm fans.
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs.
- Removable 3.5”HDD cage provides enthusiasts more convenient installation.
- Customized neat cable management.
- Dimension (W / H / D): 230 x 480 x 496 mm
- 5.25" Drive Bay: 4 Exposed (one could be converted to 3.5” bay)
- 3.5" Drive Bay: 1 Exposed ( converted from 5.25” bay) 6 Hidden
- 2.5" Drive Bay: 4 Hidden (two converted from 3.5” bay)
- I/O Panel: USB 2.0 x 2, Audio x 1, Mic x 1
- Cooling: Fan Bays Front: 120 mm red fan x 2, 1200RPM,17dBA (one is optional, can be swapped for one 200mm fan)
- Top: 120mm black fan x 2 or 200mm fan x 1 (optional)
- Rear: 120 mm black fan x 1, 1200 RPM, 17 dBA
- Side:120/140 mm fan x 1 (optional)
- Expansion Slots: 7 + 1
Only £52.99 inc VAT.
ORDER NOW
Bought one the other day for a build I did for a friend. Good airflow, fairly good build quality, fairly good cable management. Does the job nicely. Could be quieter but the fans can always be slowed down I guess.
