Cooler Master HAF 922.
15 Jan 2011
Midlands!
Ok i literally just ordered this case 20 mins ago.
I will be updating this thread as to my transfer of hardware from case to case this weekend.
However i was just wondering if my 4 pin power will reach all the way to the top of the mobo around the back of the case?
My PSU is an enermax 1250w if that helps?
Thanks in advance!
its a small case so you wont have a problem.
Stulid you are wrong there mate:eek:. It is massive for a mid tower. I have OCZ MOD Xstream 600w psu and had to order the 4pin power extension cable in order to reach the top of the mobo from the back as OP is suggesting.
Indeed it's quite large for a mid tower (253 x 502 x 563 mm) if you compare it to the CM 430 at the lower end of the mid-tower range (190 x 424 x 490 mm) it's quite a difference, however I think the Enermax 1250W has quite long cables?
the cables are quite long yeh i guess ill just have to trial and error with how i do my cable management. if it doesnt reach round the back i will put it at the front until i get an extention cable.
