Cooler Master HAF X
26 Aug 2009
(Sorry just occurred to me there are two thread (inside of cases / new cases) I could have posted in!)
Just moved my kit into a Cooler Master HAF X
Some of the cabling was a bit tight! especially the graphics power.
Also I couldn't put the graphics cover back on, because of using the hot swap drives - the cabling would be tricky!
Other than that, went well - cam to realise I need an 8th SATA cable for my remaining SSD drive.
Cooler Master HAF X by dancook1982, on Flickr
Cables on the AX850 are a bit short. To be fair, any PSU will struggle with a XL ATX case. Usually, you have to use cable extensions, they also can make the case look tidier, although they are not cheap.
In my case, I had to jam the 8 pin extension cable between the motherboard and the motherboard tray. I see you just routed the cable via the front :) You should tidy up the fan cables hanging around at least :p
