Cooler master half X
20 Jan 2012
Colchester
Hello everyone.
a couple of months i got a new pc which included the cooler master half x
here is a link of what my build looks like.
http://s1342.beta.photobucket.com/user/nathanael1991/library/
i couldn't really sort of the wiring as it wasn't long enough to hide most of it away.
I'm completely new to this computer website. I don't know anything much about computers or have any friends around me that could tell me useful facts about the pc
I was wondering if i could add anything to the case to make it look better. i don't know like leds, fans, anything?? please any suggestions would be greatly helpfull thankyou
Looking at the pictures, you really need to sort out your cable management. That's quite an eye sore. If the cables are too short, then you need to identify which ones, and get some extensions so you can route them behind your motherboard.
And for fans, sure there are plenty of nice LED fans around. Should be a few pictures on the web with a HAFX modded with LED fans and LED strips. One thing is to not overdo it. But first, the cables I think!
EDIT : Dear Lord!!! :p
ok thanks a lot however the link you send me is a nzxt. can that work for a cooler master case? sorry im really new to all of this.
These are just cable extensions. So yes, they will be compatible. You can maybe find cheaper, although nice breaded cables will improve the looks. Especially the 24 pin and PCIE connectors, which are the ones that will stand out.
wow is that a cosmos 2 case?
Looks like a Cosmos 2, yeah :)
YOUR BASKET
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack £25.99
1 x BitFenix Hydra Fan/LED Controller £24.98
2 x BitFenix Spectre PRO 200mm Red LED - Black £14.99 (£29.98)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98 (£13.96)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
2 x BitFenix Alchemy 3pin Fan extension 30cm - Red £3.59 (£7.18)
1 x OcUK Value SATA-II 90cm Red Data Cable (NLRB-307LOCK) £2.99
2 x OcUK Value SATA-II 45cm Red Data Cable (NLRB-302LOCK) £2.59 (£5.18)
Total : £135.74 (includes shipping : £8.75).
As an example. But you need to check the lengths, quantities, and visualise the colours and fan types and placement before jumping in (Corsair SP120 for your cooler :)).
And of course, really sort out your cable management or else it will be an expensive nothing! :)
The good thing is, you can upgrade bit by bit. The important stuff (cable extensions, hide all cables behind the motherboard tray) first, finish it off with LED fans and a fan controller for example. Cables will be cheap at least.
YOUR BASKET
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Blue £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Blue £6.49
1 x BitFenix Alchemy 8pin EPS extension 45cm - Blue £5.99
1 x Lian Li SATA-ST90B SAS / SATA II 90cm Cable - Blue £4.99
2 x Akasa SATA-III 50cm Rounded DAYGLO Blue Data Cable (Right-Angle Connectors) (AK-CBSA01-05BV) £4.99 (£9.98)
Total : £48.42 (includes shipping : £4.16).
I'd start with that or whatever colour scheme you choose. Remembering that your motherboard and graphics card are mostly towards blue. I know your front fan is red, but just see what would work for you.
can anyone explain to me what the 24, 8, 3 pin what each one is for? thank you. im hoping to sort this out sometime soon when there is enough spare cash left over the next fez months
