Hi
I looked at coolers a while back but ran out of money/effort. The aim is to get my E6400 to 3Ghz. I have done it on stock cooling, but load temps of 90 degrees was bad news, so turned it back down. At the time I was stuck between the Artic Cooling Freezer 7 Pro and the Cooler Master Hyper TX 2. The F7 seemed to perform slightly better in some tests, so thought of that. But ive just noticed the TX2 is on offer at less than a tenner! Is it any good, or should I stump up the extra £7 for the F7?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-024-CM
vs.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR
Cheers
vs.
Cheers
