Hi
This is not the first time I install air cooler but this is the fisr time i face this issue.
the mounting screws ( H ) don't lock properly.
for me , it seems the down screws which comes from included motherboard support bracket , through the motherboard, are longer than it should be
the space between the mounting screws and the motherboard almost 1/2 CM.
When I install the cooler metal bracket, it starts wiggling , and cooler won't fit firmly on the CPU.
When I put the moatherboard vertically , the cooler from the top will lean out
Not only that , the paste will get dry or will slides down
I tried to contact Cooler Master, but the answer this is normal , and they want me to start to computer and check the temps??
I watched videos how to install maybe I've done something wrong, but no, there is nothing special installing this cooler
any idead please?
any idead please?
