Cooler Master MasterKeys - difference to the QuickFire?
27 Mar 2012
So the Cooler Master MasterKeys range is going to have white LED version instead of just RGB.
But the QuickFire range has white LEDs too. And they use the same Cherry MX switches with the same layout.
What's the difference? I can't really tell from their website...
From a quick glance the masterkeys has centralised lighting in the keyswitch i think.
Also has some cringy images on the coolermaster website as a bonus.
EDIT: Just looked again and i was wrong, i can't actually see any big differences.
I think the only difference is brighter backlighting.
Ah, nice picture clear explanation, I get it now thank you. Basically the old one has an uneven glow.
But, that also means it's not using standard parts so I can't mod or get replacements as easily then I guess?
