- 3 Jun 2020
Hi, This is my first post, so apologies if this has been asked before. Im building myself a new PC and I've bought the Cooler Master ML240L RGB. The instructions tell you to plug the RGB cables into the supplied controller, but can I ignore that and plug the RGB cables into the RGB on the motherboard instead so the lights all sync up?
thanks in advance.
Martin
thanks in advance.
Martin
