Cooler Master Mystique 631 - max gpu length?
16 Nov 2006
I know a 5870 isn't going to fit but I was wondering about the 5850. I've read that the power connectors are on the end of the 5850 so it kind of negates the shorter card length but I could possibly make a couple of holes for these in the sideways mounted drive bays. Is the 5850 pcb still too long for this case?
Thanks.
whats the length u have to play with?
9.5in card if i remeber correctly would make it up to 10.25'in at the very most i would think so thats only .75'in longer than a standard atc and im pretty sure most mobos are wider than that since my card doesnt look like its 2'in longer than the mobo is across
It's a bit tricky for me to unplug everything and get the side off to measure. I should stop being lazy but I was hoping someone would know. I've found loads of reviews of this case but none of them mention it. Cooler master faq say the 8800 GTX and 8800 Ultra don't fit (going back a bit I know, but this is an old case!) but don't give any dimensions.
