Hi Guys
Massive demand of this case recently and OcUK now has stock
The N200 is a superb SFF chassis and really has some interesting designs. The whole case is targeted at being easy to install and maintain. Perfect for first time system builders on a budget.
Cooler Master N-Series N200 Micro-ATX Case - Black @ £34.99 inc VAT
The cooler Master n200 redefines the meaning of modernity by its edgy asymmetrical front panel and rectangle mesh design, which totally breaks the sterotype of cases. The ports are arranged vertically on the brushed I/O bar, giving it a fresh and modern look.
Features:-
- Micro ATX (Supports Mini ITX)
- Supports up to 5 fans
- Or 3 fans and a front mounted double length liquid cooling radiator.
- Supports up to 4 SSDs
- Edgy asymmetrical design with full mesh on the front panel
- Mini tower with great expandability that supports up to three 3.5" HDD and four 2.5" SSD
- Supports a 240mm liquid cooling radiator in the front
- Supports high-end graphics cards with a length of up to 355mm/14inch
- Supports air CPU cooler heights up to 160mm/6.3inch
- Supports SuperSpeed USB 3.0
- Removable dust filter under the PSU for easy maintenance
Specification:-
- Colour: Midnight Black
- Materials: Plastic bezel with mesh, steel case body
- Motherboard Types: microATX, Mini-ITX
- 5.25" Drive Bays 1 (Max. length of 5.25" device: 170mm / 6.7 inch)
- 3.5" Drive Bays 3
- 2.5" Drive Bays 4
- I/O Panel: N200: USB 3.0 x 1, USB 2.0 x 2, Audio in and out
- N200 Advanced: USB 3.0 x 2, USB 2.0 x 1, Audio in and out
- Expansion Slots 4
- Power Supply Type: ATX PS2 (Max. length: 180mm / 7.1 inch)
- Dimension 202(W) x 378(H) x 445(D) mm
- Net Weight: 4.3 kg / 9.5 lbs
- Maximum Compatibility: CPU cooler height
- w/o 120mm x 25mm side fan: 160mm / 6.3inch
- with 120mm x 25mm side fan: 140mm / 5.5inch
- Cooling System:
- Front: 120mm black fan x 2 (one XtraFlo is pre-installed)
- Rear:120mm black fan x 1 (XtraFlo pre-installed)
- Side: 120mm fan x 1 (optional)
- Top: 120mm x 15mm fan x 1 (optional)
*Graphics card length: 355mm / 14 inch
Only £34.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- 3.5" Drive Bays 3
- 2.5" Drive Bays 4
- Expansion Slots 4
- Cooling System:
ORDER NOW
