Cooler Master NR200P ITX Case Build & Mod Project
25 Jan 2006
Kent ,UK
My builds in the "Coolermaster NR200P ITX case"
The best ITX case so far I have built-in,
All quick release panels, Quick mount SSD/HDDs, even the front I/O wires Reset, HDD, LED, Power
are already fitted to an adaptor, Just plugin.
Now completed 2 Builds in the NR200P case
(1)Normal horizontal GPU Build with stock AMD RGB CPU air cooler
, Gigabyte 2070 Super White Graphics card OLD
(2)Vertical GPU build with an AIO 240mm Radiator
AMD RADEON 6800 Reference Card NEW
Things to do list
(1)artwork (completed)
(2)modding the arctic 240mm 38mm thick aio (completed)
(3)vented window panel for vertical gpu mounting, (completed)
(4) modding case feet (completed)
hardware that is used in the builds
Coolermaster NR200P MINI-ITX CASE White
Gigabyte B550I AORUS PRO AX (AMD AM4) B550 MINI-ITX MOTHERBOARD
Ryzen 3700X
Arctic Cooling Liquid freezer II 240mm AIO
Corsair 3200mh RGB KIT 16GB
Gigabyte RTX 2070 SUPER 3 fans Replaced with AMD 6800
Corsair SF750W SFX PSU
samsung ssd 500gb
seagate 4tb 2.5" hdd for storage
AMD 6800 Reference Graphics card
Pack of Akasa Silicon rubber pins
2 x Silverstone fine dust filters
2 x Star tech SATA 12" Cables
1 x Shakmods 8 Pin CPU Extension Cable
1 x Silverstone 24 PIN Extension Cable
2 x Speclux Magnetic Addressable Digital LED Strip Kit
Use something like this for white window border
(1) Double-Sided Tape Adhesive Sticky Tape for Crafts
(2)Evergreen Goods Ltd 50 Sheets A4 White Premium Glossy Self Adhesive/Sticky
on a hot day, even the Cooler master box comes in handy, PURRFECT!
The NR200P as the TG window in the box with the case
NR200P accessory box that contains: 2 x SICKLEFLOW 120mm fans, PWM fan splitter, GPU Riser Cable, & a bag of screws with cable ties.
Another nice feature, The front I/O wires are fitted to an adaptor so you only need to push in the right way up on the motherboard.
Front 2.5" HDD mounting up to 1.7cm width with the front panel on.
Used 2 x 12" Short SATA Cables
Replaced the 2 top panel Coolermaster pwn fans with Arctic P12s white
Modding the case feet
I changed the case feet to ones that can be adjusted in height,
where the stock feet once were.
Now I have some height from the ground I can mount 2 more Arctic P12s using easy silicon rubber fan Pins under the bottom panel,
I also have ARGB Strip around them.
Reused the stock feet screws & holes in the bottom panel &
drilled 2x 1mm holes into the new feet base & screw the feet on.
If you don't want to use a drill on the feet then you can use 3M
Sticky double-sided sticky pads.
Case Around 93% Tidy will improve in the near future, The PCI-E power cable will be changed to white one soon also.
The Finished Build
Normal horizontal GPU Build with stock AMD RGB CPU air cooler.
Hello, ya Since its a great case & be doing some mods, I made my own thread in this section
& watching & posting in the normal case section:)
Hey orbital, Long time no chat :)
Working on window panel for vertical GPU
new case feet
Arctic cooling liquid freeze 240mm AIO
Some other things.
Nice mod! Looking to build in NR200! Is it possible to mount 3.5in HDD in the front or we struck to only mounting HDD in front of PSU Shroud as I'm going for Dual Rad Custom loop, one Rad on the side panel and one at the bottom!
Hello & thank you,
This thread be updated later today with my Arctic Liquid II 240mm AIO Modded Build
The Front Case Frame as 2 x 2.5" SSD/HDD mounts
May be able to use some holes to mount a 3.5" on the front, Otherwise, you got the PSU Shroud.
Case difficult to get at mo
Yes its the best ITX case I had the pleasure to build in & selling fast all over
was lucky to get one of the first Pre-orders from OCUK,
Will be posting my main AIO build today, been working on it for the past week trying things out.
Update 04/09/2020
AIO Project build/Mod
Purchased the "ARCTIC LIQUID FREEZER II 240mm" a week ago
Been finding out how to install this 240mm Radiator in an optimal Spot,
The only way was by using the side rail frame, this way be no good
in mounting the GPU in the vertical position, so I turned the case
upside down & switched top & bottom panels, to install the radiator in an
an optimal spot for the flow at the top.
There's a drawback on having the case turned upside down that may effect some
is that the window side is facing your left-hand side on the table/desk,
In my CASE this was an advantage.
Was going to turn the front case frame around by
taking out the 8 black screws from the top left & right & bottom left & right
& also drilling out the POP-Revit's that join it to the motherboard frame.
but instead went for the Front I/O facing down.
did not want to weaken the structure & damage the case,
So used the top panel with front I/O holes for the bottom.
6CM Legs & 3M Sticky pads
Using the top Panel for the bottom with the fans mounted underneath
6CM Legs for good spacing from floor & fans
Changed the stock P12s
White PCI-E extension Cables with cable clips
4TB Seagate 2.5" & a 500GB Samaung SATA SSD
View of the back of the motherboard frame Showing the corsair sf750 PSU.
The Arctic 240mm Radiator in the Optimal position for the liquid flow
Updated my AIO Build above with artwork
My build setup all fans as Exhaust, bottom 2 fans taking out warm air from the GPU & PSU
vents in the window pull air in for the GPU.
Measurements /Resize on The Artwork & onto special Photo printing paper
Waterproof.
printed out by an Epson XP-750 Inkjet
Ryzen 3700x Desktop temps depending on Auto boost from 34/41c
GPU temps around 35c idle 0db fans off till 60c
Corsair SF750w PSU 0db fan is off till 350w under load
The only sound from the PC is the pump.
Nice build, lots of modding, love the artwork.
Question for you on compatibility:
In its normal orientation, would the Liquid Freezer fit on the side panel with the GPU in its normal horizontal orientation? How is the clearance between it and the PSU cover?
THis case is so intriguing as to what you can fit in, my main wonder is if you can get 280mm AIO on the side, a hard drive on the PSU cage, two 2.5" SSDs upfront, and a two and a half slot GPU in the bottom (horizontal).
Hello, Not used the side rail, but an arctic 240mm be fine on the side with GPU in its normal horizontal position
280mm also be fine
RADIATOR SUPPORT - SIDE 120mm, 140mm, 240mm, 280mm, (not compatible with vertical GPU installation).
2.5" SSD/HDD on PSU Shroud be fine & 2 x 2.5"
on the front frame :)
be a little more tricky mounting a 3.5" HDD to the PSU shroud.
280mm also be fine
Thanks Darren. I thought a 3.5" could go on the PSU shroud, i'll look up the manual.
Beautiful build Darren, especially the artwork. One of the best I've seen for an ITX setup. Now to sit back and admire your work :)
