Beautiful build Darren, especially the artwork. One of the best I've seen for an ITX setup. Now to sit back and admire your work![]()
Thank you, Was thinking of doing the top panel & left side Panel also.
Thank youNeat little build. Really like the art work on the front.
Hi Darren, I am just about to buy this case and would like to ask you if its possible to make/fit a push pull cconfig for the AIO I have the H105 wich is also 38mm thick3.5" can go on the shroud but takes space up being a 3.5"
could be a bit tricky in some builds.![]()
Is it possible to mount 3.5in HDD in the front or we struck to only mounting HDD in front of PSU Shroud as I'm going for Dual Rad Custom loop. Showbox jiofi.local.html tplinkloginLol why not.
Good build, very unique.
Nice mod, the cat picture is my favMy builds in the "Coolermaster NR200P ITX case"
The best ITX case so far I have built-in,
All quick release panels, Quick mount SSD/HDDs, even the front I/O wires Reset, HDD, LED, Power
are already fitted to an adaptor, Just plugin.
I Now have done 2 Builds in the NR200P case
(1)Normal horizontal GPU Build with stock AMD RGB CPU air cooler
(2)Vertical GPU build with an AIO 240mm Radiator
Things to do list
(1)artwork (completed)
(2)modding the arctic 240mm 38mm thick aio (completed)
(3)vented window panel for vertical gpu mounting, (completed)
(4) modding case feet (completed)
but still trying other feet.
hardware that is used in the builds
Coolermaster NR200P MINI-ITX CASE White
Gigabyte B550I AORUS PRO AX (AMD AM4) B550 MINI-ITX MOTHERBOARD
Ryzen 3700X
Arctic Cooling Liquid freezer II 240mm AIO
Corsair 3200mh RGB KIT 16GB
Gigabyte RTX 2070 SUPER 3 fans
Corsair SF750W SFX PSU
Samsung SSD 500GB
Seagate 4TB 2.5" HDD for storage
Pack of Akasa Silicon rubber pins
2 x Silverstone fine dust filters
2 x star tech SATA 12" Cables
1 x Shakmods 8 Pin CPU Extension Cable
1 x Silverstone 24 PIN Extension Cable
2 x white PCI-E Cables
Speclux Magnetic Addressable Digital LED Strips
3M double-sided sticky pads
Magnetic tape
on a hot day, even the Cooler master box comes in handy, PURRFECT!
The NR200P as the TG window in the box with the case
NR200P accessory box that contains: 2 x SICKLEFLOW 120mm fans, PWM fan splitter, GPU Riser Cable, & a bag of screws with cable ties.
Another nice feature, The front I/O wires are fit to an adaptor so you only need to push in the right way up.
Front 2.5" HDD mounting up to 1.7cm with the front panel on
Used 2 x 12" Short SATA Cables
Replaced the 2 top panel Coolermaster pwn fans with Arctic P12s white
Modding the case feet
I changed the case feet to ones that can be adjusted in height,
where the stock feet once were.
Now I have some height from the ground I can mount 2 more Arctic P12s using easy silicon rubber fan Pins under the bottom panel,
I also have ARGB Strip around them.
Reused the stock feet screws & holes in the bottom panel &
drilled 2x 1mm holes into the new feet base & screw the feet on.
If you don't want to use a drill on the feet then you can use 3M
Sticky double-sided sticky pads.
Case Around 93% Tidy will improve in the near future, The PCI-E power cable will be changed to white one soon also.
The Finished Build
Normal horizontal GPU Build with stock AMD RGB CPU air cooler.
Cool thing about this case is the ability to 3D print your own feet as they have released a ton of options.i love the case and the build .. but i hate the legs :/
Feet. YesCool thing about this case is the ability to 3D print your own feet as they have released a ton of options.
Haha yeah I’ll make you right on thatFeet. Yes
Thrse are just short legs![]()
I mean, If the cat makes another appearance I'm not going to be mad
Oh and yeah, do update us on the build![]()
This is fantastic!!!
Not really much more to do, Arctic 240mm rad on top, All fans are set at "Exhaust"
GPU draws air in from modded window & most warm air Exhaust out the bottom & rear,
Thermal Charts in games not needed, due to AIO & the motherboard
as 8 True 90amp phases with Heat-pipe & great VRM Heatsink
No Hardware Components get hot, All cool & silent.
The only upgrade in the near future will be GPU 3070/3080 Gamerock
Hardware Unboxed
first you add feet to improve airflow then you put something under your pc to block it.. hmm?
I mean... it is blocking that massive space very effectively :>
The only thing that blocking the Exhaust: cat Warming up
