Cooler Master on/off switch
9 Feb 2011
Devon
Is it possible to get an on/off front switch for a Cooler Master Centurion case?
Case is fine it's just the switch that's knacked.
TIA
Hayseed
when the switch's go on my case's, i go to the local high street electronics shop
and get two push-to-make switch's ,one power and one for reset,and cut two holes in the front panel covers for them
You could upgrade the switch itself, the Bulgin Anti-~Vandal switches are a good replacement. You do need a drill the correct size.
If the case has a reset button and you don't need it plug the reset wire into the place where the power goes and save the hassle :)
