- 3 Jun 2013
Evening all,
Wish I had started a thread here sooner, forgot how fun it was building a new PC.
I’ve done a few builds in the past, including custom watercooled CPU/GPU in the past, but this time I wanted to build something that was:
The Hardware
Quite a few parts purchased from OCUK – although not every single one! Didn’t have this case with glass side panel!
The Rationale
I am looking for any feedback or improvements to my thought process.
How does it perform?
The Mistakes
Some odd pictures – wish I had taken more!
CPU cooler mounted on motherboard.
Space the PC is going into – quite tight if this was a full-size ATX case! (both height and length)
All-black colour scheme.
Finished build - so far - different LED colours - case is setup to fill the window with on colour!
Next steps
I do need some more RGBs.. so I will be added phanteks halo lux RGBs black aluminium to the CPU fan and the back fan. I'm not sure if I will run those as the same colour or a complimentary colour.. will have to play around.
I will also be adding another LED bar to the front of the case, and lowering the brightness of that bar and the bottom bar to minimum, as the bottom bar is a bit too strong and its linked to the top bar at the moment..
I also need to remove the top 5” drive bay.. as it's just in the way.
This should complete the look. Will post a few more pics when this is done hopefully this week!
Performance wise – next winter I will upgrade the GPU to a more powerful, yet quieter GPU, like 3060 (if it exists) and switch the front 2 fans to noctua 140mm and both the cpu and rear fan to noctua 120mms – ready to make it a really-silent gaming pc.
Any other recommended changes or things to be aware of? All feedback welcome
- Built for light gaming and also office work.
- Good looking / centre piece.
- Simple to maintain.
- Silent / very quiet.
- Upgradeable graphics.
The Hardware
- Cooler Master SILENCIO S400 Midi Tower ATX Case (with glass side panel) (+ 1 case fan on the front)
- AMD Ryzen 5 3600 Processor
- Cooler Master Hyper 212 Black Edition CPU Cooler
- Gigabyte B550M AORUS PRO mATX Motherboard
- Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4 3200 MHz C16
- MSI GeForce GTX 1660 SUPER VENTUS XS OC 6144MB GDDR6
- be quiet! Pure Power 11 500W 80 Plus Gold Modular Power Supply
- WD Blue SN550 1TB High-Performance M.2 PCI-E NVMe SSD
The Rationale
- I think the CPU, RAM was probably a solid choice.
- I think the Case is probably not well liked?
- GPU might be controversial at the moment.
- M-ATX might be questionable.
- Time of build might be considered wrong, with new CPUs and GPUs coming out.
- The Silencio S400 case because it looked good and was noise dampened - which I think does make a subtle difference. There were some reviewers saying it had an airflow problem - add a 2nd front fan and its fine.
- Ryzen 3600 because it was really good value.
- The GTX 1660 Super because my monitor is limited to 60htz at 1440p, and I’m not changing it, so didn’t see the point in upgrading any further.
- I went with a PCI-E3 SSD because I couldn’t see any real-world performance benefits from the extra £100 for a PCI-E4 SSD.
- Games are 60FPS, system is quiet and airflow is nice.
- CPU is 28-32 on idle (except for Ryzens random spikes..).
- Neither CPU or GPU spin up under normal load playing games.
The Mistakes
- GPU Brand - I picked the GPU because of the nice backplate and decent fans - annoyingly I overlooked that they run at 40% minimum. It's not too bad - but it is the noisiest thing in the case, annoyingly! It will do for a while though. I'll have to make sure next GPU can power down the fans.
- PSU Capacity - I have 500watt and it seems like RTX3070 needs much more than this.. not a good sign! I will likely go to something like a 3060, depending on performance, so might be okay.
- Gigabyte fusion RGB not as compatible as some other motherboards are! But not too bad.
- I didn’t appreciate how good RGB looked.. now I want some more!
Next steps
