Cooler Master Silent Pro 500w is now only £49.99!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
The Cooler Master Silent Pro 500w is now only £49.99! Bish bash bosh! Another great bargain.
Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply @ £49.99 inc VAT
The Silent Pro series is a new range of single rail power supplies from Cooler Master that's addressing a growing market demand for powerful single rail 12V PSUs. With up to 50A on the 12V rail, the SilentPro series deliveries where it count and won't have any problems powering even the most demanding SLI or CrossFire system,.
The SilentPro series is also the first power supply from Cooler Master to feature flat modular cables for improved airflow and cable management. It also comes with anti-vibration silicon pads to remove possible vibrations from the PSU.
- High Quality Japanese made capacitors
- 85% efficiency
- Copper and Aluminum heat pipes for high efficiency cooling
- Silicon shock absorption rubber pads around the edges of the power supply
- Modularized flat cable design to eliminate clutter and improve airflow inside the chassis
- Two 6+2 PCI-E connectors to support various graphic card setups
Only £49.99 inc VAT.
ORDER NOW
