Cooler Master SK620
5 Nov 2014
Hello All,
I have a Cooler Master keyboard which is about 7 months old.
Recently I have noticed when typing I am getting double letters appearing.
It does not do this all the time but does happen regularly. For example when typing this post out its happened 5 times with different keys.
I have taken the caps off and cleared out any dust, when its not in use I do use the plastic cover to protect it from dust as well.
Is there anything else I could try or is this going to be a fault of the keyboard?
keys it happens with is K, D, Y (this is all I can remember off the top of my head)
Same here mate. Mine is the same SK620 model and mostly happens on letters A and D. As you said this does not happens regularly, but often enough to drive me nuts when enter a password :).
I have a similar issue with my Asus Cerberus, most keys seem to be affected to some degree but have mainly noticed it on I, O, Y, T, 3, could be the frequency I use those keys and/or position on the KB making those appear more troublesome.
I was wondering if perhaps installing o-rings would help it, but don't really want to spend several hours and some money doing that if it won't!
The KB has always had the issue from shortly after I got it and varies from missing keystrokes to duplicates of keystrokes (most I've noticed is 4-5). I had wondered if it was just that the switches are a bit **** (Kalith Blacks, I've only ever used Cherry reds before), but can't imagine it would have made it to release in that state - Should have RMAd it when I first noticed it tbh!
