If you had to choose between the two, tell me why please.
XFX Pro Series Black Edition 850
Cooler Master V850
If it came down to the XFX and CM, which would you go with?
EDIT: I know of the Corsair AX860/860i and the EVGA Supernova G2. Though cannot see them being worth the difference in cost.
Cooler Master V850
- I can get the XFX and the CM V850 for the same price at the momen
- XFX and CM are based on KM3 Seasonic platforms.
- The XFX/CM have good plug layouts for my needs based on cable lengths and management, though I'd prefer the CM V850 for it's standard SATA molex connectors as opposed to the Berg on the XFX.
- The XFX has a hybrid fan mode (though I get the impression that really that's hit or miss and a good quality fan/fan profile by the manufacturer is better than a hybrid setup.
- CMV850 seems to be just one slight step below the Corsair AX860/860i range in terms of load balancing, and other nerdy specs - in short, it's a great performer, I suspect the XFX Is not far off however I couldn't find any review that gave me an understanding of the two's performance relatively speaking.
