Haf X, although if you wish you can swap and change panels from the 932 and HAF X like you can have the 932 side panel on the Haf X which actually looks pretty cool
also you can get a window for the right side from another Cooler Master case thats interchangable. I just wish the cable management was a bit better on the 922
