Cooler options for my Server
18 Oct 2002
Behind you... Naked!
Ok, I got a dual G34 Opteron Server Board and I have a pair of Noctua NH-U12DO coolers for it, however, the left/lower cooler actualy covers the top PCI slot.
Now, sure, I could simply use one of the lower ones, however I have a plan for it, and I really do need that top slot.
So, I am looking for a different choice of cooler.
The case that I am also going to use, is my Thermaltake Armor and that only has the ONE 120m area so using 2 AIO setups are not really possible ( unless I can wedge 2 92mm rads into there somehow? )
Anyway, can anyone recommend a great AIR cooler for that CPU thats fairly small and wont eat up so much room as the Noctuas do.
Thank you!
