I'm looking to upgrade to a 5800x whenever I can also get my hands on a 3070 or 3080. Any AIO/Fan recommendations? I'm currently using a Coolermaster Hyper 212 black edition, but with a 3600.
I'll definitely take a look at the Scythe Mugen 5, but i was also looking at the Noctua U12A (Although it is a bit more on the premium side).If space is at premium inside the case, Scythe Mugen 5 with mid dense fin stack would be actually little heavier cooler than Brocken 3 despite of "moderate" dimensions and step behind the best in performance.
https://www.overclockers.co.uk/search?ssearch=mugen+5
fuma 2 is also more compact than usual dual tower.
https://www.overclockers.co.uk/scythe-scfm-2000-fuma-2-dual-fan-cpu-cooler-2x120-mm-hs-04f-sy.html
Though they use base designed for Intel's concavish heatspreader while AMD uses convex heatspreaders.
So depending on amount of convexity in cooler's base, they might need lapping base flat for optimal performance.
(two convex surfaces make good contact only in small area)
Direct contact heatpipe coolers like Brocken 3 have flat base automatically, because of the way they are manufactured.
In "vacuum" NH-U12A would be superb cooler for limited space.I'll definitely take a look at the Scythe Mugen 5, but i was also looking at the Noctua U12A (Although it is a bit more on the premium side).
