Just bought a replacement motherboard and thought I'd replace the stock cooler while I'm at it.
Asus m5a97 pro
AMD 955 BE
I'm a bit confused by the info on airflow in relation to coolers and the position of case fans. Some say you need a fan that doesn't blow air straight up off the cpu?
I'm looking for something cheap and cheerful, around the 20 quid mark. My case only has one 120 mm front fan
xigmatek asgard midi tower
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XG
Obviously I'm not going to be doing any serious overclocking with my set up, and I'm looking for something pretty quiet because I record music.
Any advice or recommendations?
Reviews of the case say that the coolermaster Hyper 212 won't fit, at least not without a fight.
I saw a review of the case and they used a Zalman CNPS9500 cooler, so that MUST fit, right?
Any advice on fan placement and decent cheap coolers that might fit?
Asus m5a97 pro
AMD 955 BE
the Asgard’s ventilation system creates excess pressure inside, so the air will be exhausted rather than sucked in through the holes
