Cooler to Replace i5-3570k Stock Heatsink/Fan
Sorry, forgot to mention budget, it was around £30.
That's weird :/ just double checked the manual and it definitely says 150mm. Will have to just measure it myself to be sure.
Change of plan now though! Investigated a bit more and it's actually the 2tb hard drive making the noise (http://www.overclockers.co.uk/showproduct.php?prodid=HD-077-HI)... it's insanely loud though! Literally vibrates the entire case constantly! Not sure what to do with it now though...
It's just a secondary drive, so I took the power out and the noise disappeared almost completely, can't even tell the PC's on unless I put my ear really close to it :(
How much does HDD vibrate if you hold hdd in your hand and power it up?
HDDs become the loudest thing in quiet cases... sometimes even when vibration mounted... or it might be defective... as in out of balance.
