I'm thinking of upgrading the cooler on my X1800XT. I'm more concerned about reducing noise than improving performance. I'm considering:
1. Zalman VF900-Cu
2. Arctic Cooling Accelero X2
3. Thermalright HR-03
I'm concerned that unlike the standard cooler, these coolers don't exhaust hot air outside the case and that they will therefore increase the in-case temperature.
My case is a full tower case that Evesham originally supplied with the PC. There's plenty of space inside the case, but it's under-equipped from a cooling point of view. There are only slots for two exhaust fans. It came with a single 80mm exhaust fan, which I've replaced with an Artic Cooling Fan 8; I fitted a second Artic Cooling Fan 8 at the same time. I recently helped a friend build a new PC around an Antec P180; the Antec is definitely much better equipped than my own case from a cooling point of view.
My Athlon 3800+ X2 overclocks nicely to 2.5 GHz at the moment. Will I have problems with case temperatures, and therefore with overclocking and system stability, if I replace the standard cooler?
1. Zalman VF900-Cu
