If i have posted this in the wrong place can a mod put it in the correct place please.
I purchased a Thermalright 120 Ultra for my socket 939 mother board which is this make Asus A8N5X
I bought the cooler to go with the AMD 4200+ which is a TWO and is a bit 2 much for me old cooler
I took the mounting bracket off around the cpu as was told to do in the instalation guide onlt to find i only got 2 holes instead of 4 which is needed for the mounting plate
Due to my lack of motherboard know how i thought that this would fit as i got a 939 motherboard
Do you think i could get a refund for this as i only got it today or is it my own fault due to limited know how with a PC
I have had to order one of these Artic Coolers today to help cool me little beasty
. My fan had my AMD 3700+ single core at 2.8 stable and didnt go over 41 under load and 31 idle. You guys wasn,t joking when you said these duel cores are hot
Thank you for any info, help or advice
showing me the other attachment for it i have got the item on the way. It seems like if you got a gigabyte or dfi board your gonna have to purchase the steel back plate as well
