Anyone intrested in cooling down their X1950 read on
D/L the 6.9 Cats or better the 6.9's with a modded original control panel
You will need to Hack the driver "inf" files (add x1950xtx lines from you drivers supplied on the CD) or search for the ones already posted on this forum.
D/L Ati tool 0.25 beta16pre3.exe and dissable all the X1000 options in the settings, You can now use the fan control to set sensible speeds while staying quiet. The default ATI setting is 13% fan speed up to 77c....Crazy
The Card runs tiers of performance Desktop/3D/Overdrive the drivers/bios switch these along with extra volts, You will only get the desktop and 3D settings with the old control panel (with the overdrive tab clicked)
If You need More performance You will have to run the CCC with Your choice of Overdrive settings
Tip, Don't mess with any settings in Atitool We are Just using it to allow temperature monitoring and Fan control, Sure I read somewhere on my travels there is some sort of issue with NF4 motherboards (I experienced this Myself) and X1950's but had no time to look into it...Just thought It might help someone
You should now run in the 40c in desktop instead of 60/70c
Bit Sad to need to have to do this on a new card, but there you go
