cooler
16 Sep 2012
hi guys i have a i5 2500k in strike x gt case i have 2 side panel mounted 120mm fans and need to now of a cpu cooler that will fit without having to remove the top side fan for it to fit i have in this comp right now a asus lion square which would not fit in new case with side fans so i was looking @ maybe a h80 refurbed as ther only £40 and small please let me know what you think i will be trying to get my 2500k to 4.oghz so would a h80 be good enoughas i want to order as soon as poss thanks
If you have a good enough cpu cooler you wont need the top side panel fan. A h80 will do the job though.
thanks jumper i have very little knowledge on cpu coolers only ever using 2 a arctic freezer pro rev 2 on a q9550 which was good and this asus lion on 2500k if a h80 would match this id be happy as im really choosing the h80 on cosmetic looks for the case and trying to get the cpu to 4.0ghz as my mobo was a h67 that cant be clocked so upgraded mobo with help from you guys and ram and gc and case lol just waiting on a hdd and il be putting it together
