Could anyone tell me if tubes on cm seidon 240v are long enough to be fitted in nzxt s340 case in the front ? Cant find any info about tube lenght anywhere as the radiator cant be fitted on top
I've seen two lengths for the 240v tubes quoted around the net (retailers/forums): 250mm and 315mm (the latter more likely to be accurate). But which is accurate? Well we know the length of the S340 is 432mm so let's do some maths.
Put the fans in push at the front, then the rad behind them (with the tubes at the top), and add the bit of space from the front panel to where the fans actually mount, and that's easily 77mm gained already. The distance from the rear of the case to the centre of the CPU socket is roughly 120mm (on a typical ATX board of 244mm width). 432 minus 77+120 = 235mm. Meaning even if the tubes were only 250mm they'd still probably fit.
Both the 240v and the Masterliquid only have a two year warranty though. I'd be looking at Antec H1200 around that price range (comes with blue led fans though) with 315mm tubes.
