- 6 Jul 2009
I have just finished trransfering my system from my olf miesh mid toer to this new case. To be honest i haven't been impressed sure it has more space, the drive bays are good but the fans are loud. My main dissapointment is the cable solutions yes it has the back panel removeable and the motherboard panel is mounted a cm or two in so there should be space to run wires behind but then there is this lip on the back so you don't have as mush space to get the wires in. The removeable panels don't fit back on very easily either.
Are there better PSU's for cable tidying than others?
