Hey guys,
Hope I've posted this in the right section, not sure if it's cooling or case related. Please move it if it's in the wrong place
I've just purchased the case for Christmas and after reading about on the forum I purchased 2x140mm and 1x120mm Fractal fans to replace the ones in the case as I want it to be quite quiet. My question is in what config should I have them set up? Obviously the front 140mm needs to be intake but what about the back 120mm and the top mounted 140mm? I've got an arctic 7 pro freezer at the moment which is blowing air toward the back of the case so should it be that the 120mm is exhaust and the top mounted 140mm is intake or the other way around?
Also, I've got a 9800gt which is blowing air downwards so should the bottom mounted PSU be fan facing up (thus drawing in hot air from the GFX and pushing it out the back) or down (drawing cool air in from the bottom and leaving the gfx card air to rise to top)?
Cheers for any help.
