19 Nov 2011 at 19:09 #1 Godoftrance Godoftrance Associate Joined 16 May 2011 Posts 5 Location Belfast Hello guys i have a 690 and im ineed of some mod ideas.
19 Nov 2011 at 19:10 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Change the LED fans and strip light from Blue to Red?
19 Nov 2011 at 19:16 #3 Godoftrance Godoftrance Associate OP Joined 16 May 2011 Posts 5 Location Belfast Replace the fans with non-led? and run strip light round the inside of case window?
19 Nov 2011 at 19:35 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare A white LED fan in the front? - http://www.overclockers.co.uk/showproduct.php?prodid=FG-012-XG&groupid=701&catid=57&subcat=1816 Swap the blue strip for a White one and change any other LED fans in there for White 120mm versions?
20 Nov 2011 at 17:18 #5 FallshirmjAEger FallshirmjAEger Associate Joined 8 Dec 2010 Posts 476 Location Leicester, England You could add a white LED side fan for even more light I suppose. Off topic, but how high is the side fan mount on the CM690 II window edition? Is the top of the fan level with the top pci bracket? Looking into getting this case & want to know if i can fit a side fan with my cpu cooler.
