- 3 Jan 2008
- Devon, UK
Hi all.
This is my first post on a forum that I have been browsing for quite some time now, and have decided to jon cos you all seems like such a lovely bunch!
I'm looking at buying a CM690 case, and house my own watercooling kit inside it. My question is to anyone who has this case, at the top of the case, there are 2 x 120mm fan vents. Can these fans be installed between the chassis and the bezel, or do they have to go on the inside of the case? Would it require much modification to fit the fans there? I'm hoping to mount a 120 x 240mm radiator on the inside of these vents.
Thanks in advance.
Thanks in advance.
