Hi,
I have this great case which creates an annoying problem. Most of the times when the cpu works hard, the temperature rises and the fans of the system (cpu, vga etc) rev up, then there is a vibration noise: the case "rattles" for a few seconds, then stops, then rattles again and so on.
In the beggining I solved it by putting some small sticky pads between the side door and the case. After some days of no noise the problem came back. I can solve it for a few minutes if I press the door case but that doesn't last for long.
Any ideas?
I just cant believe it how such a wonderful case has this cheap annoying problem!!
thanks
Any ideas?
thanks
