- 24 Aug 2009
Hello, im currently going to go and buy a coolermaster 932 haf soon and do a few things to it. After crimbo, i am planning on getting a new build which will involve this case. I'm going to go with a black and red theme, so the things i want to know/do about the case;
I want to paint it black, so could i sand it down abit and just spray it as its still together (not taking apart) can i do tht or do i have to take revits out etc?
I believe there is a 140mm exhaust fan that you get with the case, is it possible to change and put a 120mm fan with no problems?
Also, the fans that is already in the case, are they 3 pin or molex because i want to get a fan controller?
Please help and thanks
