Coolermaster Amazing Case & PSU price!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
I have some truely awesome deals for any new PC build.
Coolermaster Storm Scout Gaming Case - Black @ £59.98 inc VAT
CM Storm is celebrating the deployment of the Scout™ true gaming chassis, created in close cooperation with the world’s leading professional gaming teams and eSports organizers, including Kode5, Team Fnatic and mousesports. Like all gear developed in the CM Storm Labs, the Scout has been heavily injected with Storm Tactics™ to ensure complete Strength, Security, and Control to the discerning gamer. Developed with elite engineering skills, and reinforced by the highest grade materials, your Storm gear will perform and deliver with unfailing reliability, letting you focus on your game and worry less about your hardware. The Scout has been built around a solid steel body, and comes equipped with a 140mm front intake fan, as well as 140mm top and 120mm rear exhaust fans, providing an accurate airflow to efficiently manage the heat from your gaming hardware. The aggressive window side panel, with its dark automotive tint, provides mounting locations for yet another 2 x 120mm fans to deal with thermal hotspots from overclocked CPUs and GPUs. The Scout has been fortified even further with the patented StormGuard™ accessory; this unique and widely acclaimed security solution from the CM Storm Labs consists of a specially designed PCI-bracket located at the rear of the chassis body. By locking your peripherals and side panel firmly in place, Storm Tactics and the StormGuard will protect your PC and gaming gear from thieves and other thuggish individuals whenever you are AFK. Never again return to your seat at a LAN-party, only to find that some villain has grabbed your gaming mouse and headset, or even worse, your entire system.
- Solid Steel Body for strenght and stability
- Features sturdy carry handles for taking to your favourite LAN events
- Unique security feature protection for your system and peripherals
- 4 x 5.25" drive bays
- 5 x 3.5" drive bays
- Bottom mounted PSU support
- Front I/O Port: eSata, FireWire, 4 x USB, HD audio
- Front Cooling: 140mm intake fan (included)
- Top Cooling: 140mm exhaust fan (included)
- Rear Cooling: 120mm exhaust fan (included)
- Side Cooling: 2 x 120mm intake fan (optional)
Was £66.99 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
Cooler Master GX 650W Power Supply @ £54.99 inc VAT
The latest addition from Cooler Master is a range of power supplies that specifically targets the upper mid-range to high-end gaming systems, the Coolermaster GX Series. The Coolermaster GX range of power supplies feature a single powerful +12V rail that has been designed to delivery more than ample power to dual graphics card systems, no matter if you use SLI or CrossFireX.
- Compliance with the latest Intel standard ATX 12V
- Single +12B rail for the most demanding SLI configuration
- High effciency design that meets 80 Plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multipe protection design (OVP/ UVP / OPP / OTP / SCP)
- High reliability (MTBF > 100,000)
- Double Layer EMI Filter restrains noise and injury to end-user
- Huge bulk capacitor for hold up time > 17ms at full load
- Integrating Active PFC with PWM combo controller not only make PFC higher than 0.99, but also raises efficiency
- Efficent transformer for reducing 5Bsb power loss when the system is at turn-off and sleep modes
- Five Year Warranty
Was £66.99 Inc. VAT
Only £54.99 inc VAT.
ORDER NOW
Thanks, I thought it might be. I was looking at getting a new graphics card and case (current one is very limited for cooling) soon-ish but I have the enough cash for a case now.
I hadn't made up my mind between the Dominator or Scout but this has swung it firmly in the Scouts favour. Order on its way :)
I can't wait for it to arrive :) It should drastically improve my cooling compared and it will still fit in my desk bay.
Cool case. But I will be going for HAF X. Its the best price around £130. Will be £140 in total with delivery.
IF not Antec 1200 or higher. Next week or after :)
Thanks OC
