Coolermaster ATC-110B missing door washer
10 Mar 2004
I have one of these beauties boxed up and in superb condition (the internal chassis and windowed side panel are actually brand new) and was considering making use of it for my next "significant" build, yes, I know it would probably appreciate further if I just left it to mature like a fine wine, however, it has one minute but significant flaw.
One of the five tiny washers that sits on the door hinge and is responsible for allowing the door to perfectly align with the chassis when it closes is missing, hence, no matter how perfect everything looks, the door is 1mm out of kilter and will not close without a gentle "lift". I've been to every hardware store in the vicinity looking for washers as small as these and have drawn blanks on every occasion.
Can ANYBODY here (.......Yewen :) ) inform me where I might locate just ONE of these damn washers as I very much doubt Coolermaster will be able to quell my agony!
Contact CM, if they do not have any then you will have to do what soemone else did.
Go to a machine shop / metal workers of some kind and get them to make you a new one up. Should not cost to much.
110b, as in black...?
No, 110B as in "with window"!
Didn't know there was a black version! Thought they only did black versions of the 111 and 201.
Anyway, thanks for the tip!
Ahh, your missing letters after it. The boxes with just 110b on are black, not many of them about I tell you!
Need to wake up I think, or go back to bed...
Just try that, contact CM and then get onto someone to make you a few up.
Have you tried some of the model engineering suppliers... They make some washers that are unbelievabley small....
Well worth a look..
Sam C
