Coolermaster black widow power switch
12 Feb 2004
Manchester
hi guys
im in need of power switch for my coolermaster black widow.
ive done a goggle search and found the CM Parts shop in NL is the only place i can find,
is there any UK based sites that sell them?
cheers!
I don't think there is. Even if there is we probably wouldn't be able to say as it would be classed as a competitor.
just a power switch? bah im looking for a non-windowed side panel for a black widow, emailed the parts shop in NL and had no reply :(
surely its not a competitor if OCUK dont stock it as its more a specialised part?
I have a Black Widow as well. Awesome cases aren't they! Mine has been relegated to media center duties because my new gaming rig is housed in my Silverstone TJ03.
Unfortunately, I don't think they ever made a non windowed side panel in that superb Black Widow mirror finish. Your best bet is to get a regular 201 panel and refinish it.
I'm hoping somebody can prove me wrong, because I want a non-windowed panel as well!
ah its absolutely brilliant!
i ran into a few problems with not being able to soft mount the lower intake fan, no space, grr! and my ninja effectively makes the removeable tray as good as useless as its so large but all in all, great looking case, preferred getting a second hand BW to a new lian-li pc7, always had a soft spot for old skool CM cases, not the new tat they're making now ;)
usually it takes me around 2 hours to transplant a system into a new case, spent 6 hours in the BW yesterday :/ and i've still not done things like install the CM black alu dvd bezel..
they didnt make a none windowed version that is correct, As said the parts centre in the NL is your best bet for small items they have loads just drop them an email and be patient they will get back to you. items for the ATC cases are getting more rare by the day
